ingress egress rate limiting
Aug 4th, 2008
Hello;
I want to limit bandwidth of ethernet routers connected to a 3560 switch. I want to configure ingress and egress bandwidth differently. So; ethernet routers will have X Mbits upload and 4X Mbps download limit. You can imagine it like ADSL. Is it possible?
Overall Rating: 5 (1 ratings)
Collin Clark Mon, 08/04/2008 - 13:10
  • Purple, 4500 points or more
In the configuration, the IP standard ACL permits traffic from network 10.1.0.0. For traffic matching this classification, the DSCP value in the incoming packet is trusted. If the matched traffic exceeds an average traffic rate of 48000 bps and a normal burst size of 8000 bytes, its DSCP is marked down (based on the policed-DSCP map) and sent:
Switch(config)# access-list 1 permit 10.1.0.0 0.0.255.255
Switch(config)# class-map ipclass1
Switch(config-cmap)# match access-group 1
Switch(config-cmap)# exit
Switch(config)# policy-map flow1t
Switch(config-pmap)# class ipclass1
Switch(config-pmap-c)# trust dscp
Switch(config-pmap-c)# police 48000 8000 exceed-action policed-dscp-transmit
Switch(config-pmap-c)# exit
Switch(config-pmap)# exit
Switch(config)# interface gigabitethernet0/1
Switch(config-if)# service-policy input flow1t
class-map match-all c_Outbound
match access-group 101
class-map match-all c_MarkDSCP
match access-group 102
class-map match-all c_Inbound
match ip dscp 60
policy-map p_Outbound
class c_Outbound
police 1528000 8000 exceed-action drop
policy-map p_MarkDSCP
class c_MarkDSCP
set dscp 60
policy-map p_Inbound
class c_Inbound
interface FastEthernet0/11
switchport access vlan 110
switchport mode access
service-policy input p_MarkDSCP
spanning-tree portfast
interface FastEthernet0/12
switchport access vlan 12
service-policy input p_Outbound
service-policy output p_Inbound
This was on a 3550 and you should double check and make sure it works!
Hope that helps.
yatisspor Mon, 08/04/2008 - 13:17
could you please explain this config shortly? I couldn't understand that it is the same that i was looking for:)
rajib_das Mon, 08/04/2008 - 20:46
hi,
You can do it by srr-queue command for egress b/w limit in 3560 switch .
Since the limitation of srr-queue is that it only limit b/w 90%(max) of port speed.
if u rusing 100 Mbps port then you should made the port speed 10 Mbps (by command speed 10)
then u apply command srr-queue bandwith limit 40 which gives exatly 4 mbps link ( say X- = 1 Mbps)
For Ingres B/w limiting you can follows the input by Collin.
thanks
rajib
Collin Clark Tue, 08/05/2008 - 05:52
In the simplest form, we mark the traffic, then police it. Using an ACL we mark all traffic to/from a source (in this case I use an ACL that matches a public IP I give a customer). Once the traffic is marked, I then police it to whatever speed they purchased. The QoS SRND is a very helpful guide.
http://www.cisco.com/application/pdf/en/us/guest/netsol/ns432/c649/ccmigration_09186a008049b062.pdf
Hope that helps
Marwan ALshawi Mon, 08/04/2008 - 21:08
  • Community Spotlight Award,
    Best Publication, December 2015
first of all i would say Collin config perfect and he has done professionaly from marking and policing prespectives
however
i may guess that Murat not so familier with Qos and Polices in depth
so what i could sugest for easier reasons not for any other reason
is
make a limiting on each router itself for all traffic regard less of the traffic type
as requested in the question there was no requirment for traffic types
so on each router to the same idea as follow
class-map map1
match any
policy-map input1
class map1
plice 10000 confirm-action transmit acced-action drop
then
policy-map output1
class map1
police 40000 confirm-action transmit acced-action drop
then go to the interface facing the switch
interface fa0/0
service-policy input input1
service-policy output output1
in this case u have policed and limited the all kind of traffic based on down or up stream
by the way the rates i have used for example u can put what ever limits u want 1Mb 5 MB as u want and u can follow the same idea for all routers
good luck
please, Rate if helpful
