okuehn Tue, 08/05/2008 - 00:23
  • Bronze, 100 points or more
Hi Hiram,
please note that photos will not be supported if you use global catalog port TCP 3268 instead of normal LDAP port TCP 389
actually we have ran into this issue...
regards, Oliver
hlarriuz Wed, 08/06/2008 - 07:35
How do you load the photos in the AD, I saw a few solutions, any sugestion.
DOUG DAVIDSON Wed, 08/06/2008 - 13:50
so it will not work when using the global catalog? Does Cisco have any plans to fix it?
okuehn Wed, 08/06/2008 - 22:20
no, it does not work using GC because GC servers do not hold the photo attribute. see also
http://msdn.microsoft.com/en-us/library/ms679116(VS.85).aspx
however, using GC is cisco's recommendation due to several performance problems with CUPC and LDAP
it does not seem to be fixed in the near future, so we are heading to implement the photo using a web server.
