Cisco Unity 5.0/ Can't find messages
Answered Question
Aug 4th, 2008
I'm running Cisco Unity 5.0, Message are being stored on a different Exchange server. Are Exchange server went down for maintenance over the weekend.
Now when attempting to access Cisco Unity. I getting the following error. "Your message are not available". I also not able to check other message or send message. Users can only log on.
I have attempted to reboot about 5 time. I have also rerun the permissions wizard. I did not get any errors when running DBWalker or Directory Access Diagnostics.
Any help would be great.
Correct Answer by thfergus about 8 years 7 months ago
Your messages are likely stored in the \Commserver\Unitymta or \Commserver\Unitymta\Failed folders. It sounds like your Unity server is in UMR mode.
Did anything else change? Were any mailboxes moved, particularly the mailbox for the unity_servername account ?
On the security tab of the properties for the mailboxstore in the Exchange System Manager, ensure deny is not checked for "send-as" and "receive-as" rights for the account which the AvCsMgr service is using to log-on as.
Overall Rating: 5 (1 ratings)
Correct Answer
thfergus Mon, 08/04/2008 - 11:44
  • Cisco Employee,
RSwartzmiller Tue, 08/05/2008 - 03:55
After uninstall outlook from the Unity server, and reboot everything working fine now.
5 points for the help
