Unity MWI Slow Version 5 UM
Aug 4th, 2008
Unity 5.01, UM, Exchange 2007/Windows server 2008. MWI on takes about 5-10 seconds, off approx. 20-30 seconds. Messages deliver promptly into Outlook. Is this normal, and is there an ES or MS patch for either the Unity server or Exchange server? No install issues, followed the pdf, on same subnet w/Ex.
Thanks!
Overall Rating: 5 (2 ratings)
mwheinz Tue, 08/05/2008 - 04:52
Thanks for the response. I have seen this but we can't find the hotfix, in addition, the customer's Exchange is at SP1 rollup 3, the latest. In the posting you sent, they advise only rollup 2 is eligible. Is this true and can you email the fix?
Mike
ranpierce Tue, 08/05/2008 - 07:59
  • Silver, 250 points or more
I have the same issue and I am also at rollup 3. TAC told me this.
I see in the Unity logs that MWI is turned on as soon as Unity receives TABLE_ROW_ADDED from MAPI. Exchange 2007 is installed on Server 2008.
There is a known issue with MAPI Push Notification with Exchange 2007 on Server 2008. The fix will be released on 9/02/2008 in Rollup 4 Exchange
2007 SP1.
Here is the word from Development:
1) Exchange 2007 on W2k8 has an issue with MAPI Push notifications so MWI will sometime fail. The KB article number is 951251, might not be visible yet, but is should be in SP1RU4 exchange release which will ship in September according to MS.
We are trying to get it from MS now though.
Randy
Bradford Magnani Sat, 09/20/2008 - 13:11
  • Cisco Employee,
I posted this same info in a newer thread recently. TAC has submitted a defect in order to track the progress of the Rollup release by Microsoft. Microsoft's slated release date is the week of 9/22/08 at this point. See the bug toolkit link below.
http://tools.cisco.com/Support/BugToolKit/search/getBugDetails.do?method=fetchBugDetails&bugId=CSCsu62686
Hope this helps,
Brad
ranpierce Tue, 10/07/2008 - 11:59
Brad or anyone,
do you know what has happened to the update?
last the bug said 9/22
My subscribers have been complaining.
Randy
Bradford Magnani Tue, 10/07/2008 - 12:14
  • Cisco Employee,
I see you have a TAC case open. Feel free to update this thread with your results.
Brad
ranpierce Tue, 10/07/2008 - 13:44
It just came out a few minutes before I posted it.
There was a beta version earlier that did not work.
When did you try it?
Randy
ranpierce Tue, 10/07/2008 - 13:58
hmm around 9/22 when it was supposed to comeout.
I opened a tac sr and got this email from tac.
Sure, Randy. Case closed. Your timing was perfect as SU 4 was only released a few minutes before your SR.
Have a great week!
I have been waiting for it a long time.
Randy
gonzalezel Tue, 10/14/2008 - 13:06
do you know if this is an issue with exchange 2003 running on windows server 2003? We are having the same issue.
David Hailey Mon, 02/23/2009 - 18:52
  • Purple, 4500 points or more
Did anyone verify that the fix in RU4 resolves the 2k8/Exchange 2k7 issue?
