GSS - demote primary?
adamtroxel
How do you go about demoting a primary - and bringing the secondary into primary mode?
We would like to swap the roles of our secondary and primary units
adamtroxel
nevermind. a little reading and gssm primary-to-standby
To demote a master GSSM-M to a standby GSSM-S, issue the following command on the primary:
gss-primary #gssm primary-to-standby
To promote GSSM-S to Primary
gss-sec# gssm standby-to-primary
details at
http://www.cisco.com/en/US/docs/app_ntwk_services/data_center_app_services/gss4400series/v1.3/administration/guide/Man_CLI.html#wp1025535
Syed Iftekhar Ahmed
sachinga.hcl
Level 4
Level 4
Ensure that the designated primary GSSM is either offline or configured as a standby GSSM before you attempt to enable the standby GSSM as the new interim primary GSSM. Having two primary GSSM devices active at the same time may result in the inadvertent loss of configuration changes for your GSS network.
Log in to the CLI of the primary GSSM, enable privileged EXEC mode, and perform a full backup of your primary GSSM to preserve your current network and configuration settings
After entering the gssm primary-to-standby command, you should ensure that at least 1 minute passes before you enter the gssm standby-to-primary command in order to allow time for proper GSS device synchronization.
Configuration changes do not take effect immediately. It may take up to 10 minutes before the other GSS devices in the network learn about the new primary GSSM.
Kindly refer the following document:
http://www.cisco.com/en/US/docs/app_ntwk_services/data_center_app_services/gss4400series/v2.0/administration/guide/Man_CLI.html#wp1025322
Kindly rate if you find it useful.
Sachin Garg
