ASA transparent mode with secondary IP on the router
Answered Question
Aug 4th, 2008
I have
Router --- ASA (Transparent)----Switch
and just wonder if it is possible to configure secondary IP on the router interface which is connected to ASA
so there is plenty of room in terms of LAN IP range.
Or to implement this, do I have change ASA to context mode and modify configuration on the ASA?
hope I do not have to change anything on the ASA.
Correct Answer by Marwan ALshawi about 8 years 9 months ago
ASA in transparant mode work as L2 device
so what ever ips u use dosent matter
u dont need to change anything in the ASA while it is in transperant mod
but be careful of what is allowed to be passed through the firewall
u can control it by ACLs
the router and the switch u have will operat in L3 as thy connected directly or nothing between them from routing and layer three prespective
so they shoud be in the same subnet VLAN and so on
good lcuk
please, if helpful rate
Overall Rating: 5 (1 ratings)
Correct Answer
Marwan ALshawi Mon, 08/04/2008 - 19:07
  • Purple, 4500 points or more
  • Community Spotlight Award,
    Best Publication, December 2015
good lcuk
