LMS 2.6 Corrupt
Answered Question
Aug 4th, 2008
Another cry for HELP !
The server that hosts our LMS2.6 application crashed overnight after some Microsoft Updates were applied and now LMS2.6 is totally unusable !!.
When I launch the application it is okay , but going into Campus Manager/Topolgy Services it simply pops up a red hexagon with an "Error" .
I think that the database is completely corrupt , how do I reset it and start again ?
Scott
Correct Answer by Joe Clarke about 8 years 5 months ago
Your path is wrong. It should be:
D:\PROGRA~1\CSCOpx\databases\ani\ani.db
Overall Rating: 5 (1 ratings)
Joe Clarke Tue, 08/05/2008 - 00:02
Please post the output of pdshow as well as the recursive directory listing of NMSROOT\databases. Your database may not be corrupt. It may just be the transaction log.
Joe Clarke Tue, 08/05/2008 - 08:36
I also need the recursive directory listing to be able to tell if this is DB corruption or transaction log corruption:
dir /s NMSROOT\databases
Joe Clarke Tue, 08/05/2008 - 20:59
In each of the databases subdirectories, you will find a .log file (e.g. rmeng\rmeng.log). Delete each of these files. Then, for each database, run:
NMSROOT\objects\db\win32\dbsrv9 -f DBFILE
For example:
NMSROOT\objects\db\win32\dbsrv9 -f NMSROOT\databases\rmeng\rmeng.db
Once you have done that for each database, restart Daemon Manager. You should be up and running again.
sdawson35 Tue, 08/05/2008 - 21:11
Hi again :-),
This does not work :-(, I get a message about the file not being able to opened
"Could not open/read file:\cscopxdatabases\ani\ani.db (I have tried all differant directory structure options)
Correct Answer
Joe Clarke Tue, 08/05/2008 - 21:13
sdawson35 Tue, 08/05/2008 - 21:34
Sir !, You are a star :-)
All is now working as it should , I am a very happy chappy, thankyou very much.
Scott
