Problem with Installation of CUCCX 7.0
Aug 4th, 2008
I am facing a problem concerning installing the beta version of CUCCX 7.0 in terms of licensing.
The received copy contains a license which demands to enable the high availability feature under windows server 2003; as this feature does not exist in the standard edition which I am using in our labs, I will be glad to know if there is a way to install CUCCX 7.0 under the SE as the enterprise edition which supports the HA feature is not currently available for application in our labs or if there is another license which does not need the high availability feature to be enabled.
