Translation group asa 5505
Aug 5th, 2008
Hi all,
When I try to access my dns on the 192.168.1.0/24 network from my ftp server on the 192.168.200.0/24 network, I get No translation group found for udp src dmz:192.168.200.2/23423 dst inside:192.168.1.4/53
I guess I need some additional NAT inplace?
My config:
interface Vlan1
nameif inside
security-level 100
interface Vlan2
nameif outside
security-level 0
ip address * 255.255.255.248
interface Vlan3
nameif dmz
security-level 50
ip address 192.168.200.1 255.255.255.0
interface Ethernet0/0
switchport access vlan 2
interface Ethernet0/1
interface Ethernet0/2
interface Ethernet0/3
interface Ethernet0/4
interface Ethernet0/5
switchport access vlan 3
interface Ethernet0/6
interface Ethernet0/7
access-list http_access_in extended permit tcp any any eq www
access-list dmz_access_in extended permit icmp 192.168.200.0 255.255.255.0 192.168.1.0 255.255.255.0 inactive
access-list dmz_access_in remark Specify what kind of trafic should be allowed to travle to the inside network
access-list dmz_access_in extended permit tcp host 192.168.200.2 192.168.1.0 255.255.255.0 eq www inactive
access-list dmz_access_in extended permit ip 192.168.200.0 255.255.255.0 any
access-list dmz_access_in remark For name resolution to inside name server 192.168.1.4
access-list dmz_access_in extended permit object-group TCPUDP 192.168.200.0 255.255.255.0 host 192.168.1.4 eq domain
access-list l2l_list extended permit ip 192.168.1.0 255.255.255.0 192.168.100.0 255.255.255.0
access-list ftp_access_in extended permit tcp any any eq ftp
access-list 8080_access_in remark Specify what kind of trafic should be allowed in. Don't forget the NAT
access-list 8080_access_in extended permit tcp any any eq www
access-list 8080_access_in remark This rule permits anyone to ping the outside interface 79.136.112.50
access-list 8080_access_in extended permit icmp any any
access-list 8080_access_in extended permit tcp any any eq ssh
access-list 8080_access_in remark This rule permits anyone to access out ftp server
access-list 8080_access_in extended permit tcp any any eq ftp
access-list inside_nat0_outbound extended permit ip 192.168.1.0 255.255.255.0 192.168.100.0 255.255.255.0
access-list inside_access_in extended permit udp 192.168.200.0 255.255.255.0 any eq domain
access-list inside_access_in remark This rule allows traffic to flow from bahnhof to vasagatan
access-list inside_access_in extended permit ip 192.168.1.0 255.255.255.0 192.168.100.0 255.255.255.0
global (outside) 1 interface
nat (inside) 0 access-list inside_nat0_outbound
nat (inside) 1 0.0.0.0 0.0.0.0
nat (dmz) 1 0.0.0.0 0.0.0.0
static (dmz,outside) tcp interface ftp 192.168.200.2 ftp netmask 255.255.255.255
access-group inside_access_in in interface inside
access-group 8080_access_in in interface outside
access-group dmz_access_in in interface dmz
route outside 0.0.0.0 0.0.0.0 79.136.112.49 1
dhananjoy chowdhury Tue, 08/05/2008 - 01:08
  • Silver, 250 points or more
Use this command "no nat-control".
To pass traffic from a lower security interface (DMZ) to a higher one (Inside), use ACL to permit the traffic.
dhananjoy chowdhury Tue, 08/05/2008 - 02:59
Just type in no nat-control in config mode.
myPIX(config)# no nat-control
acomiskey Tue, 08/05/2008 - 04:36
  • Green, 3000 points or more
static (inside,dmz) 192.168.1.0 192.168.1.0 netmask 255.255.255.0
