Rate-Limit BRI
Aug 5th, 2008
I was working with a co-worker who was seeing FTP choke the B channel when a remote router was on ISDN. Normally we use rate-limit on the frame-relay PVC's, which works great, but when I configured it on the BRI0/0/0 interface, I was not seeing hits on the ACL. Is rate-limit supported on BRI interfaces?
Pravin Phadte Tue, 08/05/2008 - 09:22
Can you paste the configs if possible for bri and rate limits on the interface.
regards,
pravin
jasonviar Tue, 08/05/2008 - 09:29
ip access-list standard 150
permit tcp any any eq 1364
permit tcp any eq 1364 any
int bri0/0/0
rate-limit output access-group 151 96000 12000 12000 conform-action transmit exceed-action drop
Pravin Phadte Tue, 08/05/2008 - 09:56
Hi you dont need an acl for the interface
rate-limit output 96000 12000 12000 conform-action transmit exceed-action drop
as per you configs you need to set the rate limit for 96 kilo bits and drop after 96 kbits ?
Thats whats the rate limit calculation is for the config.
Let me know what bw you want to configure/
Pravin
jasonviar Tue, 08/05/2008 - 10:11
Previn,
Thanks for the quick response! We are using the ACL to only rate-limit certain traffic (port 1364), therefore not starving other application traffic. We use it on frame-relay pvc's and it works great. Just trying to figure out why when I do a show interface bri0/0/0 rate-limit, no traffic is being rate-limited, but the B-channels will have 225/255 rx load?
Jason
Pravin Phadte Tue, 08/05/2008 - 10:18
Is it possible to provide the output of the interface for all bri you have and the configs for the same.
Pravin
jasonviar Tue, 08/05/2008 - 10:33
At this point we are back on the frame-relay connection, so show output wouldn't be helpful. Here's the interface config.
interface BRI0/0/0
description Circuit ID and Carrier
bandwidth 30
ip address x.x.x.x y.y.y.y
ip accounting output-packets
ip nat outside
ip virtual-reassembly
encapsulation ppp
no ip mroute-cache
dialer idle-timeout 300
dialer map ip x.x.x.x name name broadcast xxxxxxxxxxx
dialer map ip x.x.x.x name name broadcast xxxxxxxxxxxx
dialer load-threshold 4 outbound
dialer watch-group 8
dialer-group 1
isdn switch-type basic-ni
isdn point-to-point-setup
isdn spid1 xxxxxxxxxxxxxx xxxxxxx
isdn spid2 xxxxxxxxxxxxxx xxxxxxx
no cdp enable
ppp authentication chap
end
Pravin Phadte Tue, 08/05/2008 - 10:39
This is the problem. bandwidth 30.
interface BRI0/0/0
bandwidth 30
You have set the interface to calcalute the BW in kilobits.
So when you give show interface bri 0/0/0 it will calc according to the configured BW ie 30 Kb so it is showing you as 255/255.
If possible check also in the show interface bri0/0 where it shows as BW32K. Remove the command as no bandwdth 30. and you will see the output for show int bri0/0/0 as 64k or 128 not sure.
Bandwdith command is set for clocking forinterface.
Hope this helps
Pravin
jasonviar Tue, 08/05/2008 - 10:41
We do use that for EIGRP as well, since the frame pvc's are set as having higher bandwidth. My issue is not with the 255/255, more that the rate-limit is not working during congestion time.
Pravin Phadte Tue, 08/05/2008 - 10:51
Since it eigrp i feel it should be in there as per you configs.
I would also suggest you to try with the commnad "traffic-shape" since you are trying to limit the O/P traffic only this could be helpful you can also use the same acl for the command.
Hope this helps
Pravin
jasonviar Tue, 08/05/2008 - 10:54
Thanks again. I will look into it, but unsure why the command takes on the interface but does not work. Thanks - Jason
