ISR 1841 > config vlan & trunk
Aug 5th, 2008
Hello
Could somebody help me?
I'm having difficulties while configuring vlan and dot1q trunking on a modular 1841 router.
IOS c1841-spservicesk9-mz.124-2.XA.bin is installed on the router and according to the Cisco Software Advisor there is dot1q and vlan support.
This is the output:
router#vlan database
router(vlan)#show
VLAN ISL Id: 10
etc.
router#show vlans
No Virtual LANs configured.
router#show vlan-switch
VLAN Name Status Ports
1 default active
10 VLAN0010 active
1002 fddi-default active
1003 token-ring-default active
1004 fddinet-default active
1005 trnet-default active
VLAN Type SAID MTU Parent RingNo BridgeNo Stp BrdgMode Trans1 Trans2
1 enet 100001 1500 - - - - - 1002 1003
10 enet 100010 1500 - -
I've read that I need to use next command "Router(vlan)# vlan 10 media ethernet name VLAN0010" to add a port to a vlan.
All these commands are not helpfull or am I doing something wrong.
Switchport commands don't work and apparently only dot1q tunneling is supported.
So is this a command problem or is it better to use a newer image?
Thanks for the help
