Disable nat on between two networks
Answered Question
Aug 5th, 2008
How do I disable NAT between two networks on the same asa. Right now the NAT between my two networks 192.168.1.0/24 and 192.168.200.0/24 isn't working so I figured I could do without it.
Tried no nat-control without any luck.
Part of my config:
interface Vlan1
nameif inside
security-level 100
interface Vlan2
nameif outside
security-level 0
ip address * 255.255.255.248
interface Vlan3
nameif dmz
security-level 50
ip address 192.168.200.1 255.255.255.0
interface Ethernet0/0
switchport access vlan 2
interface Ethernet0/1
interface Ethernet0/2
interface Ethernet0/3
interface Ethernet0/4
interface Ethernet0/5
switchport access vlan 3
interface Ethernet0/6
interface Ethernet0/7
global (outside) 1 interface
nat (inside) 0 access-list inside_nat0_outbound
nat (inside) 1 0.0.0.0 0.0.0.0
nat (dmz) 1 0.0.0.0 0.0.0.0
static (dmz,outside) tcp interface ftp 192.168.200.2 ftp netmask 255.255.255.255
access-group inside_access_in in interface inside
access-group 8080_access_in in interface outside
access-group dmz_access_in in interface dmz
route outside 0.0.0.0 0.0.0.0 79.136.112.49 1
Correct Answer by cisco24x7 about 8 years 6 months ago
static (inside,dmz) 192.168.1.0 192.168.1.0 netmask 255.255.255.0
Correct Answer by andrew.prince@m... about 8 years 6 months ago
Robert,
static (dmz,inside) 192.168.200.0 192.168.200.0 netmask 255.255.255.0
Or you could write a policy nat depending on src & dst networks.
HTH>
Overall Rating: 5 (2 ratings)
Correct Answer
andrew.prince@m... Tue, 08/05/2008 - 02:54
Robert,
HTH>
Correct Answer
cisco24x7 Tue, 08/05/2008 - 02:55
