ACS appliance multiple interface usage
Answered Question
Aug 5th, 2008
Is it possible for me to use the two interfaces that are available on the 1113 box? I want to connect both of these interfaces to two seperate network segments. I did not find any thing specific in the Cosole except the set ip that would only config one interface.
thanks
Correct Answer by dhananjoy chowdhury about 8 years 6 months ago
You can use only one.
Your Cisco 1113 system has two integrated 10/100/1000-megabit-per-second (Mbps) Ethernet connectors. ACS SE supports the operation of either Ethernet connector, but not both connectors.
For more check here
http://www.cisco.com/en/US/docs/net_mgmt/cisco_secure_access_control_server_for_solution_engine/4.1/installation/guide/solution_engine/ovrvuap.html#wp1054065
Overall Rating: 4.7 (3 ratings)
Correct Answer
dhananjoy chowdhury Tue, 08/05/2008 - 03:43
For more check here
sarmohan Tue, 08/05/2008 - 03:59
The Cisco Secure ACS Appliance supports the operation of only one Ethernet connector at a time. Concurrent operation of both Ethernet connectors is not supported.
Saravanan
dehghan Tue, 08/05/2008 - 04:07
Is there any plan for the support of the second interface in later releases? This second interface might become very usefull sometimes.
thanks
Jagdeep Gambhir Tue, 08/05/2008 - 09:47
No. as of now there is no plan to make BOTH NIC operational at a same time.
~JG
