Can I attempt CCNP exam directly without completing CCNA
Aug 5th, 2008
Hi guys,
I completed my CCNA exam on 24 may 2004 but now it is expired, and i want to go for CCNP certification so can i attempt for CCNP certification directly or i have to complete CCNA before it..
Need the information urgently..
Overall Rating: 5 (3 ratings)
Brandon Buffin Tue, 08/05/2008 - 04:44
  • Purple, 4500 points or more
You can take any or all of the CCNP exams before completing CCNA. However, CCNA is a prerequisite for CCNP, so you will have to complete CCNA before you will be recognized as a CCNP.
Hope this helps. If so, please rate the post.
Brandon
markpric Tue, 08/05/2008 - 04:47
  • Cisco Employee,
You must have a valid CCNA in order to gain CCNP status. This doesn't stop you taking the CCNP exams, but even if you pass them all you won't be given the CCNP status until you retake your CCNA.
I thought a passed CCNP test automatically re-upped an expired ccna? Isn't that true anymore?
From the Cisco CCNA Page:
CCNA certifications are valid for three years. To recertify, either pass the current CCNA exam, or pass the ICND2 exam, or pass any 642 professional level or Cisco Specialist exam (excluding Sales Specialist exams), or pass a current CCIE written exam.
Brandon Buffin Wed, 08/06/2008 - 11:42
A CCNP exam will recertify an active CCNA, but will not reinstate an expired CCNA.
Brandon
jamesboprice Fri, 08/08/2008 - 11:12
Sorry if this is out of topic range but taking any of the 642-*** tests should "renew" your CCNA but for how long?
I have about another 6-7 months so I am preping to take the 642-812. How long will this give me to complete the other needed tests needed for CCNP?
And sorry to drag out but how long is the CCNP good for before having to renew?
Brandon Buffin Fri, 08/08/2008 - 11:14
Passing a 642 professional level exam will renew your CCNA for 3 years. Most individual tests are also good for 3 years, so you will have 3 years from the time of passing the first CCNP test to pass the last one. The CCNP is also valid for 3 years.
Hope this helps.
Brandon
Deramiz123 Fri, 08/08/2008 - 14:15
Hi All,
I have the same case where i was also ccna certified until 2007 of march. now,it is clear to me that to obtain status of ccna(activated) i have to take exam bearing code of 642. Am I right?
Thanks Brandon
regards
danny
Rob Huffman Fri, 08/08/2008 - 16:57
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Danny,
If your CCNA is marked as expired then sadly you must have missed the 3 year date from when you first passed. If that is the case then this will not recertify the CCNA.
Sorry my friend,
Rob
Deramiz123 Sat, 08/09/2008 - 04:19
hi,
okey, you main that, ccna candidate must update 642 just before the expiry of ccna cert? but, will can i go for ccnp exam without taking again the CCNA?
regards
danny
Rob Huffman Sat, 08/09/2008 - 06:12
  • Hall of Fame,
    Founding Member
Hi Danny,
Yes, the 642 level exam must be passed before the CCNA expires to re-certify. You are free to take the CCNP exams but you will not be certified as a CCNP without a valid CCNA cert as a prerequisite:(
Hope this helps!
Rob
