USB to Seral supporting Control-Break
Aug 5th, 2008
Does anyone know of a USB-Serial adaptor that supoorts Cisco's Break Sequence (Control-Break)?
Please specify whether it works for PC and/or Mac..
Thanks..
Rob Nockowitz
CCIE #15410
r.nockowitz Tue, 08/05/2008 - 15:59
Thanks Mark..
Can you confirm that you have successfully performed a CONTROL-BREAK on a Cisco Router?
Thanks..
Rob Nockowitz
CCIE #15140
Mark Yeates Tue, 08/05/2008 - 16:01
  • Gold, 750 points or more
Rob,
I can confirm it works on Cisco routers. Although I use tera term and the break sequence for that works fine.
Mark
timfloyd1 Tue, 08/05/2008 - 08:08
Rob,
we've used the Belkin f5u409 usb-serial adapter with great success on XP and windows family. The only issue you may run into is that the COM port assigned goes up to COM20 in some applications , so you'll have to verify which COM connection you're actually on.
r.nockowitz Tue, 08/05/2008 - 15:58
Hmm..
I have the Belkin F5U409, with the current drivers from Belkin's website.. I cannot perform a break sequence..
Are you sure that you have used yours to break into a Cisco Router? If so, what is the version of the drivers you are running?
Thanks..
Rob Nockowitz
CCIE #15410
