LMS 2.6 Login issue
Answered Question
Aug 5th, 2008
I have a user that is able to login to LMS via TACACS/SecurID without a CW local login account, he gets guest privs, is this a bug, shouldn't he be unable to log in without a local account set up?
Correct Answer by Joe Clarke about 8 years 5 months ago
Miheg is absolutely right. This has been the case since we introduced external login modules. Every user with a valid account in the external database will be allowed Help Desk access to LMS unless they have a local account in LMS granting them more access.
I used to have a patch for LMS 2.2 which worked around this. However, in LMS 2.5+ you have the option of using ACS integration. If you do full ACS integration, you can effectively prevent people with ACS accounts from having any access in LMS.
Overall Rating: 5 (2 ratings)
miheg Tue, 08/05/2008 - 05:46
No, that is the intended behavior.
Guest or helpdesk level is what he gets.
Cheers,
Michel
Correct Answer
Joe Clarke Tue, 08/05/2008 - 08:44
