PRI Configuration (for India)
Aug 5th, 2008
Any Idea how to configure pri voice service, I try some configurations but does not work.
And idea on how inbound and outbound dial peers should be configured, Im integrating this with CCM 6.x
interface Serial0/1/0:15
no ip address
isdn switch-type primary-net5
isdn incoming-voice modem 64
isdn bchan-number-order ascending
no cdp enable
voice-port 0/1/0:15
dial-peer voice 1 pots
destination-pattern 9T
port 0/1/0:15
Overall Rating: 4 (2 ratings)
Marwan ALshawi Tue, 08/05/2008 - 05:58
lets say ur CCM ip
and ur extentions between 1000 to 1999
so for calls to CCM voip dial-peer
dial-peer voice 2 voip
destination-pattren 1...
session target:ipv4
for calls going to pstn
dial-peer voice 3 pots
destination-patren 9T
port 0/1/0:15
in this case ur useres should dial 9 then the pstn number and dont dicard the 9 on CCM this based on my above dialepeer 3
or u can dicard the ( in the CCM)
do it like
destination-patren .T
port 0/1/0:15
forwar-digit all
if u want more info just post it here
please, if helpful rate
Alejandro Corte... Tue, 08/05/2008 - 20:05
ok, my dial-peer are just like that, but so if this is good in configuration the mistake is in the PRI configuracion, do you know how to configure PRI services?
Marwan ALshawi Tue, 08/05/2008 - 20:33
the fowlling things should be don regarding ur hardware moduls
so if u use wic or vwic or if its onboard or in solt one will deffer
router# clear interface s0/0/0:15
network-clock-participate wic 0
interface Serial0/0/0:15
isdn overlap-receiving
isdn incoming-voice voice
controller T1 1/0
framing esf
clock source internal
linecode b8zs
cablelength short 133
pri-group timeslots 1-24
where the :
pri-group timeslots timeslot-range [nfas_d {backup | none
| primary {nfas_int number |
nfas_group number | rlm-group number}} | service]
the follwoing link will be very helful for u
and this link to have a knowledge about hardware config
good luck
Please, if Hlepful Rate
Alejandro Corte... Wed, 08/06/2008 - 07:13
Yes, I haved also reviwed that, I attach my config is like document explain, whe i try do make a call says in the ip phone something like "the number dialed cannot allow to complete the call"
Is ccm 6.x
Marwan ALshawi Wed, 08/06/2008 - 07:25
first of all
u need to check how many digits u r forwarding
and how many digit u recieve from the gatway
u made the pots dial peer as DID
that mean the whole number will be recieved from the pstn
so is range of pstn number will be wthin
destination-pattern 605.. this one
if not
u have to either forward the full number to the CCM
and in the gateway page in CCM chose the number of digits u wanna use for internal phon
in the significant digits option
or make a translation profile on the gateway that send only 4 digits to ur CCM
so just check ur numbering paln and config
