ATA FXO
Answered Question
Aug 5th, 2008
Hi There !
I'd like to know if there is any "ATA" with FXO port.... I need to connect 2 lines from PSTN...
Should I use a 4FXO card in a router ?
Thanks.
Andrei.
Correct Answer by Brandon Buffin about 8 years 9 months ago
There is not an ATA with FXO functionality. You can use either a 2 or 4 port FXO card in your router.
Hope this helps.
Brandon
Overall Rating: 5 (1 ratings)
Correct Answer
Brandon Buffin Tue, 08/05/2008 - 04:41
  • Purple, 4500 points or more
Hope this helps.
Brandon
