08-05-2008 05:28 AM - edited 07-03-2021 04:16 PM
I have got two wlc 4402& 25 accesspoint in that ten aps are 1020 & rest of them are 1242G .In the joining process one ap is being able to get an ip address from the dhcp but after that it gives me an error
"*Mar 1 00:00:38.332: %DHCP-6-ADDRESS_ASSIGN: Interface FastEthernet0 assigned D
HCP address 10.73.34.33, mask 255.255.254.0, hostname AP001d.a1cf.b5b8
*Mar 1 00:00:39.333: LWAPP_CLIENT_ERROR: lwapp_name_lookup - Could Not resolve
CISCO-LWAPP-CONTROLLER.cisco.com
*Mar 1 00:00:48.165: %DOT11-6-FREQ_USED: Interface Dot11Radio0, frequency 2422" is anbody knows about it pls reply
08-05-2008 06:24 AM
What exactly is the problem? Did the AP that got the IP address not join the controller? To join the controller, the AP needs to either be on the same layer 3 subnet, use DHCP Option 43, be able to resolve, "CISCO-LWAPP-CONTROLLER" from the DNS address you supply via DHCP, or, you can create a helper address and forward udp port 12223 to your controller's management address.
08-05-2008 06:10 PM
Just adding to tkhan's post... Take a look over this doc.... might help you with your issue:
http://www.cisco.com/en/US/products/ps6366/products_tech_note09186a00808f8599.shtml
