strange problem with 7940/60s on CM 3.3
Aug 5th, 2008
I've got a customer on CM 3.3 and certain phones are exhibiting the following problem they are a mix of different phone types (7940/60) “randomly while on a phone call you hear a couple of beeps and then it goes to a dial tone and you can't call out or call in for about 5 minutes”
Has anyone seen anything like this before?
Thanks in advance!
chris.mann Tue, 08/05/2008 - 10:26
that's a strange one... I bet TAC will tell you to upgrade to 4.1(3), or 5.x/6.x..
Do you see anything in the traces? Or even in the event log on the subscriber, there is a cause code on the device unregistration event that might get you going in the right direction.
good luck!!
