Zone Based FW: Adding secondary address to an interface
Answered Question
Aug 5th, 2008
If you set up a secondary IP address on an interface - say int fa0/0 zone "inside" - does that immediately take effect for the traffic on that subnet? I will be working on a network where they installed too small a subnet on the inside and I'd like to ease the migration by putting on a secondary IP and let them renumber all their stuff etc. Then as final brief step I'll nuke the primary address and make the secondary primary.
Would this work? Thanks.
Correct Answer by Marwan ALshawi about 8 years 9 months ago
once u put the secondary it comes into effict
but i think for nating u need to make reload
or rstart the sessions
good luck
Overall Rating: 5 (1 ratings)
Correct Answer
Marwan ALshawi Tue, 08/05/2008 - 06:44
  • Purple, 4500 points or more
  • Community Spotlight Award,
    Best Publication, December 2015
good luck
