FXS,FXO ports not working
Aug 5th, 2008
I have 2811 router with c2800nm-ipvoice_ivs-mz.124-2.T6.bin IOS, the VIC 4 FXS/DID card and VIC 2 FXO card are installed on that router on Hwic modules. the voice ports are showed on the show version and show diag commands, but when trying to use the voice-port command, % Unrecognized command result appears. Do you have an idea how to slove this issue? please help
amacdonell Tue, 08/05/2008 - 13:55
Do you see the interfaces on a show run? (Usually they will show up if the card is recognized.) and in the Show diag do you see the interfaces Wic slot X: and it sees exactly what the card is or does it say unrecognized hardware?? That command should work with that version IOS.
Rajesh Revuru Tue, 08/05/2008 - 14:52
Do you have enough DSP resources for the required ports, show hardware will tell you exactly dsp resources.
ahmad_tamneh Wed, 08/06/2008 - 01:46
I am not sure if the show Hardware command display the DSP resources.. this is the result of show hardware command
HQ-VGW#sh hardware
isco IOS Software, 2800 Software (C2800NM-IPVOICE_IVS-M), Version 12.4
Copyright (c) 1986-2007 by Cisco Systems, Inc.
Compiled Wed 29-Aug-07 21:15 by khuie
ROM: System Bootstrap, Version 12.4(13r)T, RELEASE SOFTWARE (fc1)
HQ-VGW uptime is 19 hours, 33 minutes
System image file is "flash:c2800nm-ipvoice_ivs-mz.124-2.T6.bin"
Cisco 2811 (revision 53.51) with 251904K/10240K bytes of memory.
Processor board ID FCZ113570RU
2 FastEthernet interfaces
1 Serial(sync/async) interface
1 Channelized (E1 or T1)/PRI port
4 Voice FXO interfaces
4 Voice FXS interfaces
DRAM configuration is 64 bits wide with parity enabled.
239K bytes of non-volatile configuration memory.
62720K bytes of ATA CompactFlash (Read/Write)
ahmad_tamneh Wed, 08/06/2008 - 01:03
I can not see the voice interfaces on the show Run. here is the show diag result
WIC Slot 1:
FXS Voice daughter card (4 port)
Hardware Revision : 3.1
Part Number : 73-6918-0
Board Revision : E0
Deviation Number : 0
Fab Version : 02
PCB Serial Number : FOC10232W
RMA Test History : 00
RMA Number : 0-0-0-0
RMA History : 00
Top Assy. Part Number : 800-17016
Connector Type : 01
Product (FRU) Number :
WIC Slot 3:
2nd generation - FXO Voice daughter c
Hardware Revision : 5.0
Top Assy. Part Number : 800-21589-
Board Revision : A0
Deviation Number : 0-0
Fab Version : 04
PCB Serial Number : FOC114922X
RMA History : 00
Product (FRU) Number : VIC2-4FXO
Version Identifier : V03
Adrian Saavedra Tue, 08/05/2008 - 18:15
Hi friend,
Check with the show diag if you have PVDMs installed in your router.
If not, you can't configure voice cards.
Let us know if this is your case.
- Adrián.
