CME centralized design
ianwarb
Hi, I am currently looking at designing a solution based around CME for a small organisation with two sites. The main site has about 35 users but the remote site only has about 7 users. There is an MPLS WAN in place already between the two sites that can support QOS. I want to deploy the CME router at the main site and deploy IP phones at the remote site to register with that CME device across the WAN. Are there any restrictions to deploying this design; I have checked the SRND's but it doesn't to be clear this is achievable. Any help would be appreciated, thanks
5 Replies 5
Rick Morris
Level 6
Level 6
no limitations here.
We do this at one of our plants and remote office.
The phones register back to the central site for IP and service.
You just need to make sure you have enough bandwidth for voice and data to eliminate delay and jitter. With the MPLS you have QoS so you shuold be ok there.
Thanks very much for the reply
can you confirm the configuration on the centralised gateway. I assume you use dial peers to route calls to the remote site
thanks
Ian
all phones are built on the centralized site and all called are routed to the centralized site then out the isdn we feed the centralized site. No calls go local to the remote site. You could send them there if you wanted but we don't
config for remote site dial-peers that you might have interest in:
"Dialing pattern"
dial-peer voice 20 voip
destination-pattern [2-6]..
session protocol sipv2
session target ipv4:10.251.118.1
dtmf-relay sip-notify
codec g711ulaw
no vad
dial-peer voice 5 voip
destination-pattern 9911
codec g711ulaw
no vad
dial-peer voice 10 voip
destination-pattern 90...............
codec g711ulaw
no vad
dial-peer voice 11 voip
destination-pattern 9[2-9].........
codec g711ulaw
no vad
dial-peer voice 15 voip
destination-pattern 91..........
codec g711ulaw
no vad
SAWR001# sh ip int b
FastEthernet0/0 unassigned YES NVRAM up up
FastEthernet0/0.1 10.252.119.1 YES NVRAM up up
FastEthernet0/0.60 10.119.60.1 YES NVRAM up up
FastEthernet0/0.100 10.119.0.1 YES NVRAM up up
Serial0/0 10.250.119.2 YES NVRAM up up
Loopback0 10.251.119.1 YES NVRAM up up
Centralized site:
HAMR001#sh ip int b
FastEthernet0/0.1 10.252.118.1 YES NVRAM up up
FastEthernet0/0.60 10.118.60.1 YES NVRAM up up
FastEthernet0/0.100 10.118.0.1 YES NVRAM up up
Service-Engine0/0 10.251.118.1 YES TFTP up up
FastEthernet0/1 unassigned YES NVRAM administratively down down
Serial0/3/0 10.250.120.1 YES NVRAM up up
Serial0/3/1 10.250.119.1 YES NVRAM up up
Loopback0 10.251.118.1 YES NVRAM up up
Tunnel0 10.245.1.118 YES NVRAM up up
dial-peer voice 5 pots
no digit-strip
port 0/2/0:23
dial-peer voice 10 pots
port 0/2/0:23
forward-digits 16
dial-peer voice 20 pots
port 0/2/0:23
forward-digits 3
dial-peer voice 11 pots
no digit-strip
port 0/2/0:23
Excellent information, thanks once again
