EIGRP Interface-passive command
Hi All,
Just want to clarify something regarding EIGRP interface-passive command. I made serial0/0 passive in eigrp, but i can still routes passing to the serial link. Do i need to make the serial sub-interface passive rather than the serial interface to stop inbound and outbound advertisements?
Here are my current configs.
interface Serial0/0
description Serial0/0
bandwidth 64
no ip address
no ip redirects
encapsulation frame-relay
no ip route-cache
no ip mroute-cache
no fair-queue
service-module t1 timeslots 1
frame-relay lmi-type ansi
interface Serial0/0.300 point-to-point
description PVC TO Remote
bandwidth 32
ip address 10.209.22.153 255.255.255.252
ip accounting output-packets
ip nat outside
no ip route-cache
no ip mroute-cache
frame-relay interface-dlci 300
frame-relay payload-compression packet-by-packet
interface Serial0/0.400 point-to-point
bandwidth 32
ip address 10.203.18.125 255.255.255.252
ip nat outside
no ip route-cache
no ip mroute-cache
frame-relay interface-dlci 400
router eigrp 500
passive-interface Serial0/0
network 10.0.0.0
network 172.25.0.0
distribute-list 45 out Serial0/0.300
distribute-list 45 out Serial0/0.400
no auto-summary
no eigrp log-neighbor-changes
RTA#sho ip eigrp neighbors
IP-EIGRP neighbors for process 500
H Address Interface Hold Uptime SRTT RTO Q Seq Type
(sec) (ms) Cnt Num
2 10.209.22.154 Se0/0.300 14 18:28:09 66 5000 0 19333965
1 10.203.18.126 Se0/0.400 11 18:28:30 50 4560 0 27775706
0 172.25.209.154 Tu0 14 7w2d 10 5000 0 232438
Overall Rating: 5 (1 ratings)
royalblues Tue, 08/05/2008 - 08:36
  • Green, 3000 points or more
Yes,
The passive interface command would be required under the sub-interface.It need to reference the interface carrying the IP address
However it would prevent the formation of neighbor adjacency. If you just want to restrict routing updates, the distribute-list you configured is the correct way
Narayan
