Playing various random MOH files
Answered Question
Aug 5th, 2008
If we have 6 MOH files is it possible to play them all in a random order when someone is put on Hold?
We want customers to hear a different part of our message when they are placed on hold.
Rich
Correct Answer by Jaime Valencia about 8 years 11 months ago
unfortunately no, you can only define one MOH stream to be played per line/device.
you could only try using the external MOH audio source and try with an ipod set to shuffle songs, other than that there is no way to do so
java
if this helps, please rate
Overall Rating: 4 (1 ratings)
Correct Answer
Jaime Valencia Tue, 08/05/2008 - 08:44
  • Cisco Employee,
  • Hall of Fame,
    2011
java
