CUE - GDM's and Licensing
Aug 5th, 2008
  • Silver, 250 points or more
Good Day,
I'm running CUE 2.3.2 and have a question regarding licensing.
I currently have the allocated resources
Voicemail/Auto Attendant:
- Max system mailbox capacity time: 6000
- Default # of general delivery mailboxes: 10
- Default # of personal mailboxes: 25
- Max # of configurable mailboxes: 35
This doc: http://www.cisco.com/en/US/docs/voice_ip_comm/unity_exp/design/design21/cuevmdes.html#wp1008385
states that you can use the GDM's as personal mailboxes, my question is do you have to do anything specifically to reallocate the GDM's as personal mailboxes?
I believe I would just add a new personal mailbox and CUE would automatically create the new personal mailbox from the GDM's remaining licenses.
Any help would be appreciated. Normally I'd test this but not in my lab at the moment.
Justin
Overall Rating: 5 (1 ratings)
Rob Huffman Tue, 08/05/2008 - 09:48
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Justin,
You are most correct :) You just can't change a Personal MB to a GDM and vise-versa, these have to be removed and reinstalled.
In Cisco Unity Express 2.1, only the "Total mailboxes" column is strictly controlled by the license and the system allows you to define any combination of personal mailboxes and GDMs as long as the aggregate number does not exceed the "Total mailboxes" column.
Hope this helps!
Rob
Rob Huffman Tue, 08/05/2008 - 13:12
  • Hall of Fame,
    Founding Member
Hi Justin,
Thanks my friend! Glad to be of some (very small)assistance :)
Take care,
Rob
