WLC with ACS
Aug 5th, 2008
I have installed WLC on my network and using certificate authentication with tkip encryption.Some users are able to authenticate and have access to the domain while others are not.If I log into into the same laptop with my profile,I get wireless connectivity while a user(owner of the laptop can't).Dell laptops are company standard.What could be causing this problem?Please help...
Overall Rating: 5 (1 ratings)
krishanmistry Tue, 08/05/2008 - 10:29
What authentication mechanism are you using? If it is EAP-TLS then each user will need their own certificate.
I would push out User Certificates via GPO.
Dreadgonfly Tue, 08/05/2008 - 10:40
I am using WPA authentication with Tkip.I generated my own certificate from ACS box.
krishanmistry Tue, 08/05/2008 - 10:59
WPA is your encryption mechanism, your authentication would be EAP-TLS, PEAP, EAP-Fast, LEAP, EAP-TTLS etc
Dreadgonfly Tue, 08/05/2008 - 11:28
Encryption mismatch.On a device,connectivity starts and within 25-30 seconds,it stops.Only encryption status reverts to AES which we don't support for this setup.
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
