RSVP question
ajay chauhan
Level 7
Level 7
I have two remote location connected to MPLS cloud .Both are locations have severs those are running heartbeats to check the connectivity can I go for RSVP to reserve some bandwidth for heartbeats .
Incase RSVP is right options what will be the configuration I need to make .
I thought of implementing Priority quque but the outgoing interfaces are gigabit interface and bandwidth is limited from Service provide dont know if priority quque will help in this scenario pls suggest .
n.nandrekar
Level 4
Level 4
Hello Ajay,
I dont think that RSVP would be the right option for this, as RSVP will just reserve bandwidth at the control-plane. At dataplane you would still need to configure Qos policies on the entire path to adhere to the bandwidth reservation.
To avoid packets from getting dropped in the SP domain, you can shape your outgoing traffic to the bandwidth guaranteed by your SP. This will ensure that you donot exceed that bandwidth even when outgoing intf is gig interface.
Then you can create a priority queue for the heartbeat traffic so that this gets priority.
To achieve this effeciently, you might t deploy H-Qos with shaping the class default within the parent policy and then creating a child policy which has the priority and other classes. The H-qos support would deped o the platform that you are using.
Hope this helps.
Niranjan
(pls rate helpful posts)
