billing system for large scale deployment
Aug 5th, 2008
I have been tasked with research into some billing solutions and was wondering if anyone knows of a decent billing system that would work for a large scale, high density wireless network. The system needs to have some level of fault tolerance and be able to handle gigabit+ speeds. A Linux based system would be a plus too.
ericgarnel Wed, 08/06/2008 - 05:01
The product page does not indicate that it supports billing. Also, is it built on top of windows 2000 like the bbsm? I wound up wiping our bbsm appliances and loading pfsense on them which works much better.
I do like the features of the guest NAC appliance though
Trending Topics - Security & Network
