A question on NAT timeout options
Aug 5th, 2008
  • Bronze, 100 points or more
How does routemap-entry-timeout option of ip nat translation command work?
Can it be used with ESP translations?
show ip nat translations verbose shows,
Pro Inside global Inside local Outside local Outside global
esp 185.0.1.5:0 10.1.1.2:12C 197.20.20.1:0 197.20.20.1:0
create 00:00:05, use 00:00:01 timeout:300000, left 00:04:58, Map-Id(In): 1,
flags:
extended, use_count: 0, entry-id: 14, lc_entries: 0, Entry type : 0
From the above output it appears that by default it is 5 minutes(for ESP).
Could these timeout values be adjusted manually?
Thanks.
rsgamage1 Fri, 08/08/2008 - 05:29
So here are the translations related to two unidirectional(inbound/outbound) IPSec tunnels.
esp 185.0.1.5:0 10.1.1.2:0 197.20.20.1:0 197.20.20.1:12D
create 00:47:48, use 00:20:20 timeout:0, timing-out,
flags:
extended, esp-notimeout, use_count: 1, entry-id: 49, lc_entries: 0
create 00:48:26, use 00:02:35 timeout:300000, left 00:02:24, Map-Id(In): 2,
flags:
extended, use_count: 0, entry-id: 48, lc_entries: 0
I'm using ip nat translation routemap-entry-timeout never with dynamic NAT and a route-map
timeout:0 corresponds to the never option used in translation. However this applies only to a routemap created half entry.
Timeout value of the inbound tunnel is unchanged at 5 minutes(=300000ms).
So, for ESP traffic changing NAT translation timeout has no considerable effect and this seems to be dominated by the inbound translation timeout which is 5 minutes.
