Autonymouse AP1121 - Management Vlan and SSID Vlan
steigja
Level 3
Level 3
We are using an ACS server to authenticate wireless users to active directory this works fine. The issue occurs when we try to pull an ip and we can't fomr the dhcp. The vlan we have the SSID on is vlan 10 and the management vlan of the AP is vlan 500. The ip-helper info is correct because wired users on vlan 10 get an ip immedialty. We just can't pull one with the AP. Does anyone know the config for this? Here is my current config, the client authenticate through the ACS 4.2 but pull no ip, the only way for me to manage the ap is to have the native vlan command on there, once i remove it i can't telnet. What is the fix for this? Thanks
current switch port config ap is plugged into.
interface FastEthernet1/0/48
switchport trunk native vlan 500
switchport mode trunk
rhobab
Can you post the config of the 1121?
jbarger
Do you have sub interfaces for vlan 10 being brigged through the radio interface?
Example config below...
interface Dot11Radio0.10
description Secure Wireless access
encapsulation dot1Q 10
no ip route-cache
bridge-group 10
bridge-group 10 subscriber-loop-control
bridge-group 10 block-unknown-source
no bridge-group 10 source-learning
no bridge-group 10 unicast-flooding
bridge-group 10 spanning-disabled
interface FastEthernet0.10
no ip route-cache
bridge-group 10
Also verify that vlan 10 is allowed on the trunk interface of the switch by typing "show int trunk"
