access list issue
Aug 5th, 2008
Hi all. My cisco asa5510 has 3 interfaces, dmz,internal,external. When i use the asdm to define an access list to allow any traffic from dmz to external, i can see that it not only allows access to external but also my internal although i specifically state external from gui. Why is this so? I specifically state a rule which removes the default implicit rule because i also need to create some rules to allow some dmz servers to access my specific internal servers. Thks in advance.
Marwan ALshawi Tue, 08/05/2008 - 22:45
  • Purple, 4500 points or more
  • Community Spotlight Award,
    Best Publication, December 2015
in ASA there somthing called security level
so the higher security level can have access to the lower security level even without acl
if u have proper nating
while the lower security level need permit ACL to go to the higher
so take this into ur consideration
if u wanna control what is accessed from in side to DMZ
make acl on the inside interface in in the inbound direction
and for dmz to inside make it on the DMZ
and so on
good luck
please, if helpful rate
wenbin, your statement is rather confusing. marwanshawi is rite, do consider the security level thing while designing.
From inside to (DMZ or external), there is no need to add any access-list (access from higher security zone to lower security zone is allowed) until & unless you want to block access of internal users to go to DMZ or external.
Same goes with DMZ, from DMZ to external traffic is by default allowed, but from DMZ to internal, you need to define access-lists (going higher security zone to lower).
Make sure that you are using predefined security levels (internal=100, DMZ=50, external=0) to avoid any confusion.
