SRST Question
Answered Question
Aug 5th, 2008
If you have a router that supports 100 ip phones in SRST mode but have 120 phones, is there a way of deciding which phones will not register?
regards
colin
Correct Answer by amacdonell about 8 years 10 months ago
Create two device pools on CCM/CUCM and assign one of the device pools with the appropriate SRST reference and leave the other one set to default. From there you are able to create your Cor list's as needed on your SRST device and know that the appropriate devices are able to register.
Overall Rating: 4 (2 ratings)
gogasca Tue, 08/05/2008 - 12:27
  • Green, 3000 points or more
You can use max-phones
or ACLs to restrict specific IP/subnets or not add the SRST reference for the Phones u dont want to register in SRST mode
Correct Answer
amacdonell Tue, 08/05/2008 - 13:25
faizal_vi Thu, 06/17/2010 - 06:18
can this be acheived by manually entering the ephone-dn is the vg ?So at the time the fall back happns only these dn get registered....
Faizal
Aaron Harrison Thu, 06/17/2010 - 14:31
  • Community Spotlight Award,
    Member's Choice, May 2015
Yes - that would work.
Aaron
