ATA Fax Quality
Aug 5th, 2008
Has anyone run into issues with Faxes smudging on ATAs with a PRI? Basically some lines will smudge with parts of characters missing and other lines will have black lines running through part of them. With a normal analog line the faxes come through clear.
Pari Thiagasundaram Tue, 08/05/2008 - 12:58
Iam not a voice guy, but will give this a try.
Can you try couple of things:
1) verify that you are not experience excessive errors on the T1/E1 or PRI controller
2) Framing and CRC errors due to clock slips might be observed on E1/T1 interfaces if the on-board clock is used as the reference.
To resolve these errors, use the frame-clock-select 1 T1 1/0 command to select one of the E1/T1 ports as the primary reference. The default reference is the on-board clock.
Please rate post if it helps.
