micahcox Tue, 08/19/2008 - 00:03
You can also have it sync with an NTP time server with
sntp
or older IOS versions
ntp
bcolvin Tue, 08/19/2008 - 07:36
  • Bronze, 100 points or more
remember that the AP does not retain the time through a power off/on cycle, for the AP to have the correct time without having to set it after each power on is to use the SNTP or NTP option to retrieve the current time from a time server.
Bill
