robertson.michael Tue, 08/05/2008 - 14:44
  • Silver, 250 points or more
Cisco does not have a tool available for this, though I'm not sure if you could find a 3rd party one.
The conversion should be pretty straight-forward as the code is fairly similar. PIX 6.x commands will line up with FWSM 2.x, whereas PIX 7.x commands will line up with FWSM 3.x.
One major difference to keep in mind is that physical interfaces on the PIX will become VLAN interfaces on the FWSM.
Here are some links to the command references, which should help you work through the migration:
PIX 6.x Command Reference:
http://www.cisco.com/en/US/docs/security/pix/pix63/command/reference/cmdref.html
PIX 7.x Command Reference:
http://www.cisco.com/en/US/docs/security/asa/asa72/command/reference/cmd_ref.html
FWSM 2.x Command Reference:
http://www.cisco.com/en/US/docs/security/fwsm/fwsm23/command/reference/fwsm_ref.html
FWSM 3.x Command Reference:
http://www.cisco.com/en/US/docs/security/fwsm/fwsm32/command/reference/fwsm_ref.html
Hope that helps.
-Mike
Farrukh Haroon Wed, 08/06/2008 - 01:01
  • Red, 2250 points or more
Please keep in mind some fundamental differences between FWSM and PIX. For example FWSM needs an ACL applied in the incoming direction on EACH vlan interface to pass traffic. There are other caveats also based on your current PIX config. VPNs are not supported on FWSM (except for Management).
Farrukh
