UK E1 PRI
Answered Question
Aug 5th, 2008
  • Silver, 250 points or more
Hello:
When adding E1 PRI for UK using MGCP what would be the PRI protocol type?
Correct Answer by Steellllllllll0 about 8 years 9 months ago
I normally use PRI euro and never had any problems so far touch wood...
Correct Answer by Rob Huffman about 8 years 9 months ago
Hi Rajesh,
Hope all is well! You should check with the Service Provider but it may well be;
isdn switch-type primary-net5
Hope this helps!
Rob
Overall Rating: 5 (3 ratings)
Correct Answer
Rob Huffman Tue, 08/05/2008 - 17:08
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Rajesh,
Hope this helps!
Rob
Rajesh Revuru Tue, 08/05/2008 - 17:17
Rob:
All is good, thanks for the information,
for be the "PRI protocol type" in the CUCM GUI page. Currently have following options and i guess it would be PRI-EURO
1. PRI EURO
2. PRI Australian
Correct Answer
Steellllllllll0 Thu, 08/07/2008 - 00:25
Rob Huffman Thu, 08/07/2008 - 05:36
  • Hall of Fame,
    Founding Member
Hi Rajesh,
Sorry for the delay, I missed your reply completely :(
"PRI - EURO" should be just fine as nicely stated by Bruce. (+5 points for your good work here Bruce)
Take care buddy!
Rob
