Need Advice on Lotus notes DUCS client for Windows vista & MAC
Aug 5th, 2008
Not sure this is the right place to ask this, but still..
My client uses unity 4.0(unified messaging with Lotus notes 6.5 server version).
My client wants to know, the compatible DUCS version for Lotus notes client 7.0 for windows vista.(when he tries to install DUCS 1.2.2 for lotus notes client 7.0 on Win Vista gets error)
The same DUCS version for MAC PC also is required.
Can somebody advise the versions and where to get it.
thfergus Wed, 08/06/2008 - 03:15
Vista will require the Notes 8 client and DUC 1.2.4, which is in the
beginning stages of being qualified. Testing should be finished soon. Note that IBM no longer ships DUC, Cisco manufacturing does.
For subscriber workstations running Vista, they will have to install the Notes 8 client and the DUC 1.2.4 csClient, and then update the mail file design (the steps to do this will be in the DUC 1.2.4 help file, it's
pretty easy).
There is no support for DUCS on Mac computers:
http://www.cisco.com/en/US/docs/voice_ip_comm/unity/compatibility/matrix/cuclientmtx.html#wp195270
thfergus Wed, 08/06/2008 - 06:17
Lotus Notes Client 8 must be obtained from IBM.
Once DUCS 1.2.4 completes qualification testing, it will be available from Cisco.
