dianewalker Wed, 08/06/2008 - 06:37
Thanks for your question. Sorry for not making it clear. I want to know if there is a way to automate the VPN client so that the users only need to run the executable file. They do not need to manually type the IP address of the Concentrator, the group name and password. Also, the VPN client shortcut is copied automatically to the desktop.
Thanks.
Diane
Marwan ALshawi Wed, 08/06/2008 - 06:49
ok u can but it will be more complicated
if u use windows domain with active directory
then u can do the automatic instolation through that
and als u can use certificate authentication instead of group name and password this will authenticate on computer level and user certificate
then with xauth the user use his normal username and password
als u can findout about automation things with vpn client through changes u can do to a file called :
vpnclient.ini
u can find it after u insstal the vpn client and make chanes to it
maybe u can make changes to it and make an image to that computer and insstaled to evry new machin in this case every thing will be included
bellow part of ht evpnclient.ini content that u can change it
for example u can make the vpn run once the client login
[Main]
not;output omitted
AutoInitiationEnable=1
AutoInitiationRetryIntervalType=1
AutoInitationRetryInterval=30
AutoInitiationRetryLimit=20
AutoInitiationList=WLAN
good luck
please, if helpful rate
