08-05-2008 10:08 PM - edited 07-03-2021 04:17 PM
We currently using autonomous ap's (1130-1230) and I've noticed that the when the client roam's from one ap to another they only drop 1 or 2 seconds but sometimes the client needs to re-authenticate dropping around 7 seconds. I'm wondering how does the ap know when a client is roaming and when it needs to re-authenticate? We don't have any of the access points configured as a wds ap so I'm not too sure how it does this. Also is there any way to decrease the roaming time without going to a controller based solution?
08-06-2008 01:47 AM
yes, set up a wds ;) this will be helpful anyways.
You should also look at the signal in the places where it re-authenticates. Maybe it's just a coverage hole there.
Best regards,
Sebastian
08-06-2008 04:20 PM
Hi Sebastian
I thought that fast roaming is only supported through the use of cckm not wpa?
Nhon
