NAC Agent warning
Aug 5th, 2008
How to avoid certificate warning message in NAC CCA Agent. Everytime when user login before authentication certificate warning message appears. Please advide how to bypass it.
Overall Rating: 5 (1 ratings)
ziyadr Fri, 08/08/2008 - 07:13
you cant bypass this. you need to purchase a trusted CA certificate for your CAS.
hemen.goradia Tue, 08/12/2008 - 23:40
After implementation of NAC OOB VG in our LAN network, users are complaining of random network loss. Any guess?
ciscoforumuser Thu, 08/14/2008 - 11:34
If this issue affecting Vista and IE 7 than you can uncheck cert. check in IE as well and it will go away..
m_zabetian Thu, 08/28/2008 - 10:14
you have option to download root cert from NAC web page and then add it as trusted cert root to your network (use GPO)
cleidh_mor Thu, 09/18/2008 - 05:49
Another way to do this is to create your own CA and sign certificates for the NAC boxes with it. You can then deploy the root cert as a trusted source via AD.
