CSM, how to change a probe?
Aug 6th, 2008
i want to change a probe for an active serverfarm. But after deleting the old probe and inserting the new one, all probe entries are cleared. What is the right handling to change a probe for an active serverfarm?
huangedmc Wed, 08/06/2008 - 03:13
What did you mean all probe entries are cleared?
Like probes under different serverfarms were removed as well?
ssieger Wed, 08/06/2008 - 03:43
after configuring the new probe in serverfarm configuration mode i control the entry in the running config. But the line where the probe should appear in the particular serverfarm section is missing, there is no probe entry. If i reconfigure the probe i've used before, the old entry is visible again.
Mohamad Qayoom Tue, 08/19/2008 - 13:03
What happens if you do the following in order?
1. Create a new probe.
2. Change the probe in the serverfarms.
3. Delete the old probe.
ssieger Wed, 08/20/2008 - 03:38
if i do the steps as per dsecription, the serverfarm has no probe entry anymore. Meanwhile i've solved the problem by setting the real servers in serverfarm submode in "no inservice". After that it is possible to delete the old probe and configure a new one in that mode.
