IPCC express system software required
Aug 6th, 2008
could you please provide me with product number of the windows server 2000 that is required for installing
IPCCX version 4.5(2)? and is it orderd from cisco or microsoft ??
Chawki Salhi Wed, 08/06/2008 - 04:25
From what I know, You can't order from Cisco without being a partner.
So if you are not, just contact your Cisco partner.
With best regards,
Chawki
valiegenus Wed, 08/06/2008 - 04:31
OK,I will let cisco partnet to order it but what is the product number of that windows version to provide it to a cisco distributer and also to inquire its price form dynamic config tool.??
The Windows software is all part of the pack of CDs/DVDs that you will get when you order CRS and a MCS server for it to be installed on. It will come as the Platform Install Disc (most likely in DVD format) for the IBM or HP server depending on what is ordered for hardware.
There is no part number for the specific Windows installation that I know of when dealing with Express.
