Platform configuration disk for MCS-7825-I3
Aug 6th, 2008
I'm trying to install a Unity VoiceMail in our newly received hardware (MCS-7825-I3-CCE1/CCX1/ECS1/IPC1/RC1/S31) but the installation is failing to install because I don't have the right PCD (Platform configuration disk)
The message I'm getting is:
This Configuration CD is not
Supported on this server model
Press <ESC> to Exit
Can you please advice how to download or order this CD?
Thank you
testeven Wed, 08/06/2008 - 13:05
The only way to get this SW is placing a CD request and you need to follow the next procedure:
Go to the Product Upgrade Tool (PUT)
(registered customers only). You'll be required to enter your Cisco Software Application Support Plus Upgrades (SASU) contract number and request the CD/CD set.
If you have any problems finding the part numbers that you need or with the order placing please send an email to [email protected]
Just send them an email requesting the SW CDs that you need, adding your contract number and the shipping address.
If you have a CD mis-shipment problem, then the Customer Service department should be involved. They can be contacted at
[email protected].
For more information you can call Customer Service at 1-800-553-6387
Finally I'm sending you all the detailed info about the procedures on CDs requests, for future needs:
NOTE: Cisco TAC does not provide installation media.
Hope this helps :)
