MDS and Nagios
Does anyone use Nagios for performance monitoring of MDS's?
I am looking for configration samples.
Many thanks in advance for any help.
Kind regards,
Chris
inch
Level 3
Level 3
G'day,
Not with nagios for performance (availability yes!). For performance I use MRTG with a nice php interface that performs a snmp query on each port to get the description etc and display it all nice and pretty :)
I also have used cacti but this is a little more complicated to setup and maintain.
Cheers
Andrew
Hi Andrew,
Many thanks fr the hint. Do you have any good link to MRTG and MDS's? I want to prevent reinventing the wheel ;-)
Kind regards,
Chris
G'day,
Its pretty easy! All you need to do is setup snmp on the switch and then run the mrtg command "configmaker" :)
oss.oetiker.ch/mrtg/
There is nothing really special for the MDS'
Cheers
Andrew
