4505 Switch Backplan Utilization
Sureshdank
I am facing problem in one of my Cisco 4505 (with SUP V) switch . It is getting hang. During that time I am not able to login untill and unless I restart the switch.
During this I checked the netflow analyser and I saw there are some machines connected to the switch were transfering like terabyte of data (As 4Tb Storage is connected to that switch)
The reason what I am thinking was complete backplane utilization of the switch. Can somebody please guide me how to check the backplan utilization on Cisco 6505 switch or if not what could be the reason for switch getting hang.
Regards.
6 Replies 6
guerrad
If you issue the "sh environment" command it should show the switch bandwidth utilization.
Huh? Where?
6500#show environment
environmental alarms:
no alarms
backplane:
operating clock count: 2
operating VTT count: 3
fan-tray 1:
fan-tray 1 type: WS-C6K-13SLT-FAN2
fan-tray 1 version: 2
fan-tray 1 fan-fail: OK
VTT 1:
VTT 1 OK: OK
VTT 1 outlet temperature: 29C
VTT 2:
VTT 2 OK: OK
VTT 2 outlet temperature: 44C
VTT 3:
VTT 3 OK: OK
VTT 3 outlet temperature: 34C
clock 1:
clock 1 OK: OK, clock 1 clock-inuse: in-use
clock 2:
clock 2 OK: OK, clock 2 clock-inuse: not-in-use
power-supply 1:
power-supply 1 fan-fail: OK
power-supply 1 power-input: AC high
power-supply 1 power-output-fail: OK
power-supply 2:
power-supply 2 fan-fail: OK
power-supply 2 power-input: AC high
power-supply 2 power-output-fail: OK
module 3:
module 3 power-output-fail: OK
module 3 outlet temperature: 36C
module 3 inlet temperature: 34C
module 3 device-1 temperature: 33C
module 3 device-2 temperature: 35C
module 4:
module 4 power-output-fail: OK
module 4 outlet temperature: 35C
module 4 inlet temperature: 34C
module 4 device-1 temperature: 33C
module 4 device-2 temperature: 34C
module 5:
module 5 power-output-fail: OK
module 5 outlet temperature: 35C
module 5 inlet temperature: 33C
module 5 device-1 temperature: 32C
module 5 device-2 temperature: 35C
module 6:
module 6 power-output-fail: OK
module 6 outlet temperature: 34C
module 6 inlet temperature: 32C
module 6 device-1 temperature: 32C
module 6 device-2 temperature: 34C
module 7:
module 7 power-output-fail: OK
module 7 outlet temperature: 35C
module 7 inlet temperature: 28C
module 7 device-1 temperature: 40C
module 7 device-2 temperature: 40C
module 7 asic-1 temperature: 27C
module 7 asic-2 temperature: 27C
module 7 asic-3 temperature: 27C
module 7 asic-4 temperature: 27C
module 7 asic-5 temperature: 27C
module 7 asic-6 temperature: 27C
module 7 RP outlet temperature: 32C
module 7 RP inlet temperature: 32C
module 7 EARL outlet temperature: 44C
module 7 EARL inlet temperature: 30C
module 9:
module 9 power-output-fail: OK
module 9 outlet temperature: 56C
module 9 inlet temperature: 28C
module 10:
module 10 power-output-fail: OK
module 10 outlet temperature: 54C
module 10 inlet temperature: 29C
module 11:
module 11 power-output-fail: OK
module 11 outlet temperature: 58C
module 11 inlet temperature: 30C
module 13:
module 13 power-output-fail: OK
module 13 outlet temperature: 54C
module 13 inlet temperature: 29C
module 13 device-1 temperature: 29C
module 13 device-2 temperature: 44C
chassis connector rating: 1260.00 Watts (30.00 Amps @ 42V)
module 3
module 3 connector rating: 1260.00 Watts (30.00 Amps @ 42V)
module 3 power consumption: 100.38 Watts ( 2.39 Amps @ 42V)
module 4
module 4 connector rating: 1260.00 Watts (30.00 Amps @ 42V)
module 4 power consumption: 100.38 Watts ( 2.39 Amps @ 42V)
module 5
module 5 connector rating: 1260.00 Watts (30.00 Amps @ 42V)
module 5 power consumption: 100.38 Watts ( 2.39 Amps @ 42V)
module 6
module 6 connector rating: 1260.00 Watts (30.00 Amps @ 42V)
module 6 power consumption: 100.38 Watts ( 2.39 Amps @ 42V)
module 7
module 7 connector rating: 1260.00 Watts (30.00 Amps @ 42V)
module 7 power consumption: 315.00 Watts ( 7.50 Amps @ 42V)
module 9
module 9 connector rating: 2016.00 Watts (48.00 Amps @ 42V)
module 9 power consumption: 277.62 Watts ( 6.61 Amps @ 42V)
module 10
module 10 connector rating: 2016.00 Watts (48.00 Amps @ 42V)
module 10 power consumption: 325.50 Watts ( 7.75 Amps @ 42V)
module 11
module 11 connector rating: 2016.00 Watts (48.00 Amps @ 42V)
module 11 power consumption: 325.50 Watts ( 7.75 Amps @ 42V)
module 13
module 13 connector rating: 2016.00 Watts (48.00 Amps @ 42V)
module 13 power consumption: 254.94 Watts ( 6.07 Amps @ 42V)
chassis per slot cooling capacity: 83 cfm
ambient temperature: < 55C
The questions was about a 4500 and not a 6500.
Sorry it looks like he was asking about both and i missed the 6500 section.
Here are my results from a 4500 with a SUP-V
4500-SupV#sh environment
no alarm
Chassis Temperature = 39 degrees Celsius
Chassis Over Temperature Threshold = 75 degrees Celsius
Chassis Critical Temperature Threshold = 95 degrees Celsius
Power Fan Inline
Supply Model No Type Status Sensor Status
PS1 PWR-C45-1300ACV AC 1300W good good good
PS2 PWR-C45-1300ACV AC 1300W good good good
Power supplies needed by system : 1
Power supplies currently available : 2
Chassis Type : WS-C4506-E
Power consumed by backplane : 0 Watts
Switch Bandwidth Utilization : 0%
Supervisor Led Color : Green
Module 1 Status Led Color : Green
Module 2 Status Led Color : Green
Module 3 Status Led Color : Green
Module 4 Status Led Color : Green
Module 5 Status Led Color : Green
Module 6 Status Led Color : Green
Fantray : Good
Power consumed by Fantray : 50 Watts
Very nice, I've been looking for a command on the 4500 that shows that!
On the 6500 you can use 'show fabric utilization' to show fabric bandwith usage, and 'show catalyst6000 traffic-meter' to show DBUS usage.
-Ryan
