08-06-2008 04:22 AM - edited 03-15-2019 12:26 PM
What is the way to check the CUE service engine logs to see if the module had restarted ? ( something like sh version)..
What are the possible causes of a CUE module rebooting on it's own even when the router hosting it didn't go down?
Any insights will be greatly appreciated.
Solved! Go to Solution.
08-07-2008 05:16 AM
Not sure if this is what you are hitting, but
There is a bug, CSCsm67312 where 3.1.1 would reboot every 20 days when SNMP monitoring was turned on.... The workaraound was either to upgrade to 3.1.2 or to disable SNMP monitoring..
Hope this helps
08-06-2008 07:03 AM
Show log name then the name of the log you want to see (sh logs will give you the list)
but what version of CUE are you running? and is it on a NM or AIM?
The reason I ask is there was a bug in some of the older versions of the CUE that would either cause it to hang or reboot, I had a similar problem and a software update fixed it for me (I don't remember the exact versions...)
08-07-2008 12:50 AM
Hi Marc,
Thanks for your reply.
The version of CUE is 3.1. It's an NM. Does it have any known bugs?
Ashok.
08-07-2008 05:16 AM
Hope this helps
08-07-2008 06:02 AM
Marc,
You are bang on target! SNMP monitoring is indeed turned on for What'sUp Professional!
Thanks for the immense help I received from you.
Have a nice day.
Take care,
Ashok.
08-07-2008 06:11 AM
Anytime man!
