08-06-2008 04:32 AM - edited 03-11-2019 06:26 AM
I have two asa 5510 . i am not able to configure failover amongst the as all the features are same except web vpn peers .Once has 25 and other has 2.Pl suggest how to resolve this .The show version o/p is attached for reference
08-06-2008 05:02 AM
Kaushik,
please see the below configuration guides for failover:-
HTH>
08-14-2008 02:31 AM
You can't have failover unless both Web VPN peers are the same. You need to purchase the same WebVPN licenses for the secondary box and then failover will work fine provided you have the other prerequisutes met as in same rev of code, and correct license for failover etc..
HTH..
Chris
