Easy VPN connection with remote side behind NAT device
Marwan ALshawi Thu, 08/07/2008 - 06:24
try to issue the following comman
no crypto dynamic-map outside_dyn_map 20 set nat-t-disable
shanevolpe Thu, 10/02/2008 - 06:43
I'm trying to do the same thing you are: Establishing a VPN using the ASA5505 when it is behind a NAT. Did you have to open/forward any ports from the NAT device to the ASA5505 to get the VPN connection working?
Marwan ALshawi Thu, 10/02/2008 - 06:50
if u case like
internet---nat device--ASA--internal
and the vpn on the ASA
u need first static nat or portforward from the nat device to the ASA
u need the folling ports opned and nated staticly
esp
udp 500
and mybe udp 4500
to get the tunnel established
if helpful Rate
singhsaju Fri, 10/03/2008 - 09:13
Can you enable NAT-T globally on both end ASAs and then check .
"isakmp nat-traversal 20 "
http://www.cisco.com/en/US/docs/security/asa/asa70/configuration/guide/ike.html#wp1052899
When NAT-T is enabled , the ESP packets,(which actually vcarries data payload) which gets blocked by PAT/NAT, gets encapsulated in UDP 4500 packets and since it now has ports it can easily pass through PAT.
Saju
Pls rate helpful posts
