CCM 5.1 with SIP gateway
Aug 6th, 2008
Hi, I have a CCM 5.1 cluster with two voice gateways at site A and one voice gateway at site B. The first gateway of site A uses E1 interface and have been working fine. Now, I'm configuring the second gateway with a SIP provider. In the future I will retire the E1 gateway. I want to configure the SIP connection at gateway instead the CCM because the SRST. I have tried some configurations without success. Does anyone can help me?
tks
Rodrigo
Chad Stachowicz Wed, 08/06/2008 - 06:42
  • Silver, 250 points or more
Rodrigo I would need to know what type of credentials your service provider provided you with. Your configuring all this under sip-ua on the gateway correct? please paste what you have and give me what the provider gave you except some fake username ip and pw or whatever, and I will help you.
Cheers!
Chad
rdamaso Wed, 08/06/2008 - 12:16
Hi, Chad.
My setup is the follow.
phone ( dn 4000 ) ---> CCM 5.1 ---> by H323 ---> GW ---> SIP provider
The provider just provide me the IP address. I didn't receive any username or password. I did the configuration of this IP through SIP trunk at CCM and the solution works fine.
I think that my gateway have to do the internetwork between H323 and SIP. I don't konw.
The commands that I have been attached in the router are below.
voice service voip
redirect ip2ip
sip
voice class codec 1
codec preference 1 g729r8
codec preference 2 g711alaw
codec preference 3 g711ulaw
dial-peer voice 1 voip
destination-pattern 4...
voice-class codec 1
session target ipv4:( CCM_IP )
dial-peer voice 10 voip
destination-pattern .T
voice-class codec 1
session protocol sipv2
session target sip-server
session transport udp
sip-ua
registrar ipv4:( SIP_PROVIDER_IP )
sip-server ipv4:( SIP_PROVIDER_IP )
Tks
Rodrigo
